Group: DynoMotion Message: 14338 From: az9633@ymail.com Date: 1/13/2017
Subject: KCNC jog button problem
Hello,
I'm  using 4.33
I'm setting up an XYZ router .
I have the Coordinate system set up as (0,2,1,-1) for wiring convenience.
I lost the Jog button function on K CNC at some point then it returned then I lost it again while I was accessing the init file in K motion to get the axis directions correct.
When I lost the Jog function the first time, I was able to get it back by Closing KCNC and Kmotion and just reopening them again and running the init file.( I think).  Now I just open KCNC and still cannot get the Jog buttons to work but I can run a G code program OK.
Is there any problem in having both Kmotion and KCNC open at the same time? I like to go back and forth between the two for diagnostic purposes.
When I run an init file on K CNC, does that override the last program I ran in a K motion thread?  What if the init file in KCNC was assigned to run on a thread that  was running a run forever program that was previously initiated in Kmotion?
 I will be adding a Y2 axis slaved to the Y once I get the main operation correct.  I'm assuming all I have to do to accomplish that is set the Y2 (ch3) axis as a slave to Y (ch2) and the coordinate system assignments stay the same.  Is that correct?
Below is my init file.
Any thoughts?
AZ
//Init3Destiny_A gaint set x reverse
    int BitA,Change1=0,Change2=0, DiffX2;
    int PosNoWrap, NewPos, Pos=0, wraps;
    double Factor=0;
//Setting Fet outputs
    SetBit(152);
    SetBit(157);
    SetBit(158);
    ch0->InputMode=ENCODER_MODE;
    ch0->Vel=100000;
    ch0->Accel=1e+006;
    ch0->Jerk=1e+01;
    ch0->P=0.17;
    ch0->I=0;
    ch0->D=0;
    ch0->FFAccel=0;
    ch0->FFVel=0;
    ch0->MaxI=10;
    ch0->MaxErr=50000;
    ch0->MaxOutput=2000;
    ch0->DeadBandGain=1;
    ch0->DeadBandRange=0;
    ch0->InputChan0=0;
    ch0->InputChan1=0;
    ch0->OutputChan0=0;
    ch0->OutputChan1=0;
    ch0->MasterAxis=-1;
    ch0->LimitSwitchNegBit=0;
    ch0->LimitSwitchPosBit=0;
    ch0->SoftLimitPos=1e+009;
    ch0->SoftLimitNeg=-1e+009;
    ch0->InputGain0=-1;
    ch0->InputGain1=1;
    ch0->InputOffset0=0;
    ch0->InputOffset1=0;
    ch0->OutputGain=1;
    ch0->OutputOffset=0;
    ch0->SlaveGain=1;
    ch0->BacklashAmount=0;
    ch0->BacklashRate=0;
    ch0->invDistPerCycle=0.00025;
    ch0->Lead=0;
    ch0->MaxFollowingError=50000;
    ch0->StepperAmplitude=100;
    ch0->iir[0].B0=1.000000;
    ch0->iir[0].B1=0.000000;
    ch0->iir[0].B2=0.000000;
    ch0->iir[0].A1=0.000000;
    ch0->iir[0].A2=0.000000;
    ch0->iir[1].B0=1.000000;
    ch0->iir[1].B1=0.000000;
    ch0->iir[1].B2=0.000000;
    ch0->iir[1].A1=0.000000;
    ch0->iir[1].A2=0.000000;
    ch0->iir[2].B0=0.002945;
    ch0->iir[2].B1=0.005890;
    ch0->iir[2].B2=0.002945;
    ch0->iir[2].A1=1.832150;
    ch0->iir[2].A2=-0.843926;
    ch1->InputMode=ENCODER_MODE;
    ch1->Vel=100000;
    ch1->Accel=1e+006;
    ch1->Jerk=1e+01;
    ch1->P=0.17;
    ch1->I=0;
    ch1->D=0;
    ch1->FFAccel=0;
    ch1->FFVel=0;
    ch1->MaxI=10;
    ch1->MaxErr=20000;
    ch1->MaxOutput=2000;
    ch1->DeadBandGain=1;
    ch1->DeadBandRange=0;
    ch1->InputChan0=1;
    ch1->InputChan1=1;
    ch1->OutputChan0=1;
    ch1->OutputChan1=1;
    ch1->MasterAxis=-1;
    ch1->LimitSwitchNegBit=0;
    ch1->LimitSwitchPosBit=0;
    ch1->SoftLimitPos=1e+009;
    ch1->SoftLimitNeg=-1e+009;
    ch1->InputGain0=1;
    ch1->InputGain1=1;
    ch1->InputOffset0=0;
    ch1->InputOffset1=0;
    ch1->OutputGain=-1;
    ch1->OutputOffset=0;
    ch1->SlaveGain=1;
    ch1->BacklashAmount=0;
    ch1->BacklashRate=0;
    ch1->invDistPerCycle=0.00025;
    ch1->Lead=0;
    ch1->MaxFollowingError=50000;
    ch1->StepperAmplitude=100;
    ch1->iir[0].B0=1.000000;
    ch1->iir[0].B1=0.000000;
    ch1->iir[0].B2=0.000000;
    ch1->iir[0].A1=0.000000;
    ch1->iir[0].A2=0.000000;
    ch1->iir[1].B0=1.000000;
    ch1->iir[1].B1=0.000000;
    ch1->iir[1].B2=0.000000;
    ch1->iir[1].A1=0.000000;
    ch1->iir[1].A2=0.000000;
    ch1->iir[2].B0=0.002945;
    ch1->iir[2].B1=0.005890;
    ch1->iir[2].B2=0.002945;
    ch1->iir[2].A1=1.832150;
    ch1->iir[2].A2=-0.843926;
    ch2->InputMode=ENCODER_MODE;
    ch2->Vel=100000;
    ch2->Accel=1e+006;
    ch2->Jerk=1e+01;
    ch2->P=0.17;
    ch2->I=0.00;
    ch2->D=0;
    ch2->FFAccel=0;
    ch2->FFVel=0;
    ch2->MaxI=10;
    ch2->MaxErr=50000;
    ch2->MaxOutput=2000;
    ch2->DeadBandGain=1;
    ch2->DeadBandRange=0;
    ch2->InputChan0=2;
    ch2->InputChan1=2;
    ch2->OutputChan0=2;
    ch2->OutputChan1=2;
    ch2->MasterAxis=-1;
    ch2->LimitSwitchNegBit=0;
    ch2->LimitSwitchPosBit=0;
    ch2->SoftLimitPos=1e+009;
    ch2->SoftLimitNeg=-1e+009;
    ch2->InputGain0=1;
    ch2->InputGain1=1;
    ch2->InputOffset0=0;
    ch2->InputOffset1=0;
    ch2->OutputGain=-1;
    ch2->OutputOffset=0;
    ch2->SlaveGain=1;
    ch2->BacklashAmount=0;
    ch2->BacklashRate=0;
    ch2->invDistPerCycle=0.00025;
    ch2->Lead=0;
    ch2->MaxFollowingError=50000;
    ch2->StepperAmplitude=100;
    ch2->iir[0].B0=1.000000;
    ch2->iir[0].B1=0.000000;
    ch2->iir[0].B2=0.000000;
    ch2->iir[0].A1=0.000000;
    ch2->iir[0].A2=0.000000;
    ch2->iir[1].B0=1.000000;
    ch2->iir[1].B1=0.000000;
    ch2->iir[1].B2=0.000000;
    ch2->iir[1].A1=0.000000;
    ch2->iir[1].A2=0.000000;
    ch2->iir[2].B0=0.002945;
    ch2->iir[2].B1=0.005890;
    ch2->iir[2].B2=0.002945;
    ch2->iir[2].A1=1.832150;
    ch2->iir[2].A2=-0.843926;
    DisableAxis(0);
    DisableAxis(1);
    DisableAxis(2);
    DisableAxis(0);            // disable the axis
    Zero(0);                // Zero the position
    DisableAxis(1);            // disable the axis
    Zero(1);                // Zero the position
    DisableAxis(2);            // disable the axis
    Zero(2);                // Zero the position
    EnableAxisDest(0,0);
    EnableAxisDest(1,0);
    EnableAxisDest(2,0);
    EnableAxis(0);
    EnableAxis(1);
    EnableAxis(2);
    DefineCoordSystem(0,2,1,-1);
//  Set up I/O  board
// Board address is 0,
    InitAux();
    AddKonnect(0,&VirtualBits,VirtualBitsEx);
